Правильно найти азимут
Discussion in 'ПЕСОЧНИЦА' started by 39dotyt, Oct 5, 2013.
  1. Lex K-G
    Lex K-G Форумчанин
    Ваши явы-джавы - извращение, выглядят, как на сях без одного плюса:D Давайте код на ФОРТРАНЕ))) Це оффтоп, мобила-шайтан... Бравзер - китайская белочка:D
    Под Андроид что-то пишете, если не секрет¿
  2. stout
    Да легко. ::biggrin24.gif::
    Show Spoiler
    Code:
    cb::inverse
    c
          program inverse
    c
    c********1*********2*********3*********4*********5*********6*********7**
    c
    c name:      inverse
    c version:  200208.19
    c author:    stephen j. frakes
    c purpose:  to compute a geodetic inverse
    c            and then display output information
    c
    c input parameters:
    c -----------------
    c
    c output parameters:
    c ------------------
    c
    c local variables and constants:
    c ------------------------------
    c answer          user prompt response
    c b                semiminor axis polar (in meters)
    c baz              azimuth back (in radians)
    c buff            input char buffer array
    c dd,dm,ds        temporary values for degrees, minutes, seconds
    c dlon            temporary value for difference in longitude (radians)
    c dmt,d_mt        char constants for meter units
    c edist            ellipsoid distance (in meters)
    c elips            ellipsoid choice
    c esq              eccentricity squared for reference ellipsoid
    c faz              azimuth forward (in radians)
    c filout          output file name
    c finv            reciprocal flattening
    c hem              hemisphere flag for lat & lon entry
    c ierror          error condition flag with d,m,s conversion
    c lgh              length of buff() array
    c option          user prompt response
    c r1,r2            temporary variables
    c ss              temporary variable
    c tol              tolerance for conversion of seconds
    c
    c name1            name of station one
    c ld1,lm1,sl1      latitude  sta one - degrees,minutes,seconds
    c ald1,alm1,sl1    latitude  sta one - degrees,minutes,seconds
    c lat1sn          latitude  sta one - sign (+/- 1)
    c d_ns1            latitude  sta one - char ('N','S')
    c lod1,lom1,slo1  longitude sta one - degrees,minutes,seconds
    c alod1,alom1,slo1 longitude sta one - degrees,minutes,seconds
    c lon1sn          longitude sta one - sign (+/- 1)
    c d_ew1            longitude sta one - char ('E','W')
    c iaz1,maz1,saz1  forward azimuth  - degrees,minutes,seconds
    c isign1          forward azimuth  - flag  (+/- 1)
    c glat1,glon1      station one      - (lat & lon in radians )
    c p1,e1            standpoint one    - (lat & lon in radians )
    c
    c name2            name of station two
    c ld2,lm2,sl2      latitude  sta two - degrees,minutes,seconds
    c ald2,alm2,sl2    latitude  sta two - degrees,minutes,seconds
    c lat2sn          latitude  sta two - sign (+/- 1)
    c d_ns2            latitude  sta two - char ('N','S')
    c lod2,lom2,slo2  longitude sta two - degrees,minutes,seconds
    c alod2,alom2,slo2 longitude sta one - degrees,minutes,seconds
    c lon2sn          longitude sta two - sign (+/- 1)
    c d_ew2            longitude sta two - char ('E','W')
    c iaz2,maz2,saz2  back azimuth      - degrees,minutes,seconds
    c isign2          back azimuth      - flag  (+/- 1)
    c glat2,glon2      station two      - (lat & lon in radians )
    c p2,e2            forepoint two    - (lat & lon in radians )
    c
    c global variables and constants:
    c -------------------------------
    c a                semimajor axis equatorial (in meters)
    c f                flattening
    c pi              constant 3.14159....
    c rad              constant 180.0/pi
    c
    c    this module called by:  n/a
    c
    c    this module calls:      elipss, getrad, inver1, todmsp
    c    gethem, trim,  bufdms, gvalr8, gvali4, fixdms, gpnhri
    c    datan,  write,  read,  dabs,  open,  stop
    c
    c    include files used:    n/a
    c
    c    common blocks used:    const, elipsoid
    c
    c    references:            see comments within subroutines
    c
    c    comments:
    c
    c::modification history
    c::1990mm.dd, sjf, creation of program
    c::199412.15, bmt, creation of program on viper
    c::200203.08, crs, modified by c.schwarz to correct spelling of Clarke
    c::200207.15, rws, modified i/o & standardized program documentation
    c::                added subs trim, bufdms, gethem, gvali4, gvalr8
    c::200207.23, rws, replaced sub inver1 with gpnarc, gpnloa, gpnhri
    c::200208.15, rws, fixed an error in bufdms
    c::              - renamed ellips to elipss "common error" with dirct2
    c::              - added FAZ & BAZ to printed output
    c::200208.19, rws, added more error flags for web interface code
    c::              - added logical nowebb
    c::200208.xx, sjf, program version number 2.0
    ce::inverse
    c
          implicit double precision (a-h, o-z)
          implicit integer (i-n)
    c
          logical  nowebb
    c
          character*1  answer,option,dmt,buff(50),hem
          character*6  d_ns1, d_ew1, d_ns2, d_ew2, d_mt
          character*30 filout,name1,name2,elips
    c
          integer*4    ierror
          integer*4    lgh
    c
          common/const/pi,rad
          common/elipsoid/a,f
    c
    c    ms_unix      0 = web version
    c                  1 = ms_dos or unix version
    c
          parameter  ( ms_unix = 0 )
    c
          pi  = 4.d0*datan(1.d0)
          rad  = 180.d0/pi
          dmt  = 'm'
          d_mt = 'Meters'
    c
          if( ms_unix.eq.1 )then
            nowebb = .true.
          else
            nowebb = .false.
          endif
    c
        1 do 2 i=1,25
            write(*,*) '  '
        2 continue
    c
        5 write(*,*) '  Program Inverse  -  Version 2.0 '
          write(*,*) '  '
          write(*,*) '  Ellipsoid options : '
          write(*,*) '  '
          write(*,*) '  1) GRS80 / WGS84  (NAD83) '
          write(*,*) '  2) Clarke 1866    (NAD27) '
          write(*,*) '  3) Any other ellipsoid '
          write(*,*) '  '
          write(*,*) '  Enter choice : '
          read(*,10) option
      10 format(a1)
    c
          if(option.eq.'1') then
            a=6378137.d0
            f=1.d0/298.25722210088d0
            elips='GRS80 / WGS84  (NAD83)'
          elseif(option.eq.'2') then
            a=6378206.4d0
            f=1.d0/294.9786982138d0
            elips='Clarke 1866    (NAD27)'
          elseif(option.eq.'3') then
            call elipss (elips)
          else
            write(*,*) '  Enter 1, 2, or 3 !  Try again --'
            goto 5
          endif
    c
          esq = f*(2.0d0-f)
    c
          write(*,*) '  '
          write(*,*) '  '
          write(*,*) '  '
          write(*,*) '  '
    c
      15 write(*,*) '  Enter First Station '
          write(*,16)
      16 format(18x,'(Separate D,M,S by blanks or commas)')
          write(*,*) 'hDD MM SS.sssss  Latitude :        (h default = N )'
      11 format(50a1)
    c
      22 hem='N'
          read(*,11) buff
          call trim (buff,lgh,hem)
          call bufdms (buff,lgh,hem,dd,dm,ds,ierror)
    c
          if( ierror.eq.0 )then
            irlat1 = 0
          else
            irlat1 = 1
            write(*,*) ' Invalid Latitude ... Please re-enter it '
            write(*,*) '  '
            if( nowebb )then
              goto 22
            endif
          endif
    c
          ald1 = dd
          alm1 = dm
          sl1  = ds
    c
          if( hem.eq.'N' ) then
            lat1sn = +1
          else
            lat1sn = -1
          endif
    c
          write(*,*) 'hDDD MM SS.sssss Longitude :      (h default = W )'
    c
      23 hem='W'
          read(*,11) buff
    c
            irlon1 = 0
          else
            irlon1 = 1
            write(*,*) ' Invalid Longitude ... Please re-enter it '
            write(*,*) '  '
            if( nowebb )then
              goto 23
            endif
          endif
    c
          alod1 = dd
          alom1 = dm
          slo1  = ds
    c
          if( hem.eq.'E' ) then
            lon1sn = +1
          else
            lon1sn = -1
          endif
    c
          call getrad(ald1, alm1, sl1, lat1sn, glat1)
          call getrad(alod1,alom1,slo1,lon1sn, glon1)
    c
          write(*,*) '  '
          write(*,*) '  '
    c
      20 write(*,*) '  Enter Second Station '
          write(*,16)
    c
      24 hem='N'
          read(*,11) buff
    c
            irlat2 = 0
          else
            irlat2 = 1
            write(*,*) '  '
            if( nowebb )then
              goto 24
            endif
          endif
    c
          ald2 = dd
          alm2 = dm
          sl2  = ds
    c
            lat2sn = +1
          else
            lat2sn = -1
          endif
    c
    c
      25 hem='W'
          read(*,11) buff
    c
            irlon2 = 0
          else
            irlon2 = 1
            write(*,*) '  '
            if( nowebb )then
              goto 25
            endif
          endif
    c
          alod2 = dd
          alom2 = dm
          slo2  = ds
    c
          if( hem.eq.'E' )then
            lon2sn = +1
          else
            lon2sn = -1
          endif
    c
          call getrad(ald2, alm2, sl2, lat2sn, glat2)
          call getrad(alod2,alom2,slo2,lon2sn, glon2)
    c
          p1 = glat1
          e1 = glon1
          p2 = glat2
          e2 = glon2
    c
          if( e1.lt.0.0d0 )then
            e1 = e1+2.0d0*pi
          endif
          if( e2.lt.0.0d0 )then
            e2 = e2+2.0d0*pi
          endif
    c
    c    compute the geodetic inverse
    c
    c ************************************************************
    c *  replaced subroutine inver1 with gpnhri
    c *
    c *  call inver1 (glat1,glon1,glat2,glon2,faz,baz,edist)
    c *
    c
          call gpnhri (a,f,esq,pi,p1,e1,p2,e2,faz,baz,edist)
    c
    c    check for a non distance ... p1,e1 & p2,e2 equal zero ?
    c
          if( edist.lt.0.00005d0 )then
            faz = 0.0d0
            baz = 0.0d0
          endif
    c
    c    set the tolerance (in seconds) for the azimuth conversion
    c
          tol = 0.00005d0
    c
          call todmsp(faz,iaz1,maz1,saz1,isign1)
          if(isign1.lt.0) then
            iaz1=359-iaz1
            maz1=59-maz1
            saz1=60.d0-saz1
          endif
          call fixdms ( iaz1, maz1, saz1, tol )
    c
          call todmsp(baz,iaz2,maz2,saz2,isign2)
          if(isign2.lt.0) then
            iaz2=359-iaz2
            maz2=59-maz2
            saz2=60.d0-saz2
          endif
          call fixdms ( iaz2, maz2, saz2, tol )
    c
          call todmsp(glat1, ld1,  lm1,  sl1,  lat1sn)
          call todmsp(glon1, lod1, lom1, slo1, lon1sn)
          call todmsp(glat2, ld2,  lm2,  sl2,  lat2sn)
          call todmsp(glon2, lod2, lom2, slo2, lon2sn)
    c
          call hem_ns ( lat1sn, d_ns1 )
          call hem_ew ( lon1sn, d_ew1 )
          call hem_ns ( lat2sn, d_ns2 )
          call hem_ew ( lon2sn, d_ew2 )
    c
          write(*,*) '  '
          write(*,*) '  '
          write(*,*) '  '
          write(*,*) '  '
          write(*,*) '  '
          write(*,49) elips
      49 format('  Ellipsoid : ',a30)
          finv=1.d0/f
          b=a*(1.d0-f)
          write(*,50) a,b,finv
      50 format('  Equatorial axis,    a  = ',f15.4,/,
        *      '  Polar axis,        b  = ',f15.4,/,
        *      '  Inverse flattening, 1/f = ',f16.11)
    c
      18 format('    LAT = ',i3,1x,i2,1x,f8.5,1x,a6)
      19 format('    LON = ',i3,1x,i2,1x,f8.5,1x,a6)
    c
          write(*,*) '  '
          write(*,*) '  First  Station : '
          write(*,*) '  ---------------- '
          write(*,18) ld1, lm1, sl1, d_ns1
          write(*,19) lod1,lom1,slo1,d_ew1
    c
          write(*,*) '  '
          write(*,*) '  Second Station : '
          write(*,18) ld2, lm2, sl2, d_ns2
          write(*,19) lod2,lom2,slo2,d_ew2
    c
      32 format('  Ellipsoidal distance    S = ',f14.4,1x,a1)
      34 format('  Forward azimuth        FAZ = ',i3,1x,i2,1x,f7.4,
        1      ' From North')
      35 format('  Back azimuth          BAZ = ',i3,1x,i2,1x,f7.4,
        1      ' From North')
    c
          write(*,*) '  '
          write(*,34) iaz1,maz1,saz1
          write(*,35) iaz2,maz2,saz2
          write(*,32) edist,dmt
          write(*,*) '  '
          write(*,*) '  Do you want to save this output into a file (y/n)?'
          read(*,10) answer
    c
          if( answer.eq.'Y'.or.answer.eq.'y' )then
      39  write(*,*) '  Enter the output filename : '
            read(*,40) filout
      40  format(a30)
            open(3,file=filout,status='new',err=99)
            goto 98
    c
      99  write(*,*) '  File already exists, try again.'
            go to 39
    c
      98  continue
            write(3,*) '  '
            write(3,49) elips
            finv=1.d0/f
            b=a*(1.d0-f)
            write(3,50) a,b,finv
            write(*,*) '  Enter the First Station name : '
            read(*,40) name1
            write(*,*) '  Enter the Second Station name : '
            read(*,40) name2
    c
      41  format('  First  Station : ',a30)
      42  format('  Second Station : ',a30)
      84  format('  Error: First  Station ... Invalid Latitude  ')
      85  format('  Error: First  Station ... Invalid Longitude ')
      86  format('  Error: Second Station ... Invalid Latitude  ')
      87  format('  Error: Second Station ... Invalid Longitude ')
      88  format(1x,65(1h*))
      91  format('        DD(0-89) MM(0-59) SS(0-59.999...)  ')
      92  format('        DDD(0-359) MM(0-59) SS(0-59.999...)  ')
    c
            write(3,*) '  '
            write(3,41) name1
            write(3,*) '  ---------------- '
            if( irlat1.eq.0 )then
              write(3,18) ld1, lm1, sl1, d_ns1
            else
              write(3,88)
              write(3,84)
              write(3,91)
              write(3,88)
            endif
    c
            if( irlon1.eq.0 )then
              write(3,19) lod1,lom1,slo1,d_ew1
            else
              write(3,88)
              write(3,85)
              write(3,92)
              write(3,88)
            endif
    c
            write(3,*) '  '
            write(3,42) name2
    c
            if( irlat2.eq.0 )then
              write(3,18) ld2, lm2, sl2, d_ns2
            else
              write(3,88)
              write(3,86)
              write(3,91)
              write(3,88)
            endif
    c
            if( irlon2.eq.0 )then
              write(3,19) lod2,lom2,slo2,d_ew2
            else
              write(3,88)
              write(3,87)
              write(3,92)
              write(3,88)
            endif
    c
            write(3,*) '  '
            write(3,34) iaz1,maz1,saz1
            write(3,35) iaz2,maz2,saz2
            write(3,32) edist,dmt
            write(3,*) '  '
          endif
    c
      80 write(*,*) '  '
          write(*,*) '  '
          write(*,*) '  '
          write(*,*) '  1) Another inverse, different ellipsoid.'
          write(*,*) '  2) Same ellipsoid, two new stations.'
          write(*,*) '  3) Same ellipsoid, same First Station.'
          write(*,*) '  4) Done.'
          write(*,*) '  '
          read(*,10) answer
    c
          if(    answer.eq.'1' )then
            goto 1
          elseif( answer.eq.'2' )then
            goto 15
          elseif( answer.eq.'3' )then
            goto 20
          else
            write(*,*) '  Thats all, folks!'
          endif
    c    stop
          end
          subroutine bufdms (buff,lgh,hem,dd,dm,ds,ierror)
    c
          logical    done,flag
    c
          character*1 buff(*),abuf(21)
          character*1 ch
          character*1 hem
          integer*4  ll,lgh
          integer*4  i4,id,im,is,icond,ierror
          real*8      x(5)
    c
    c    set the "error flag"
    c
          ierror = 0
          icond  = 0
    c
    c    set defaults for dd,dm,ds
    c
          dd = 0.0d0
          dm = 0.0d0
          ds = 0.0d0
    c
    c    set default limits for "hem" flag
    c
          if(    hem.eq.'N' .or. hem.eq.'S' )then
            ddmax = 90.0d0
          elseif( hem.eq.'E' .or. hem.eq.'W' )then
            ddmax = 360.0d0
          elseif( hem.eq.'A' )then
            ddmax = 360.0d0
          elseif( hem.eq.'Z' )then
            ddmax = 180.0d0
          elseif( hem.eq.'*' )then
            ddmax  = 0.0d0
            ierror = 1
          else
            ddmax = 360.0d0
          endif
    c
          do 1 i=1,5
            x(i) = 0.0d0
        1 continue
    c
          icolon = 0
          ipoint = 0
          icount = 0
          flag  = .true.
          jlgh  = lgh
    c
          do 2 i=1,jlgh
            if( buff(i).eq.':' )then
              icolon = icolon+1
            endif
            if( buff(i).eq.'.' )then
              ipoint = ipoint+1
              flag  = .false.
            endif
            if( flag )then
              icount = icount+1
            endif
        2 continue
    c
          if( ipoint.eq.1 .and. icolon.eq.0 )then
    c
    c      load temp buffer
    c
            do 3 i=1,jlgh
              abuf(i) = buff(i)
        3  continue
            abuf(jlgh+1) = '$'
            ll = jlgh
    c
            call gvalr8 (abuf,ll,r8,icond)
    c
            if( icount.ge.5 )then
    c
    c        value is a packed decimal of ==>  DDMMSS.sssss
    c
              ss = r8/10000.0d0
              id = idint( ss )
    c
              r8 = r8-10000.0d0*dble(float(id))
              ss = r8/100.0d0
              im = idint( ss )
    c
              r8 = r8-100.0d0*dble(float(im))
            else
    c
    c        value is a decimal of ==>  .xx  X.xxx  X.
    c
              id = idint( r8 )
              r8 = (r8-id)*60.0d0
              im = idint( r8 )
              r8 = (r8-im)*60.0d0
            endif
    c
    c      account for rounding error
    c
            is = idnint( r8*1.0d5 )
            if( is.ge.6000000 )then
              r8 = 0.0d0
              im = im+1
            endif
    c
            if( im.ge.60 )then
              im = 0
              id = id+1
            endif
    c
            dd = dble( float( id ) )
            dm = dble( float( im ) )
            ds = r8
          else
    c
    c      buff() value is a d,m,s of ==>  NN:NN:XX.xxx
    c
            k    = 0
            next = 1
            done = .false.
            ie  = jlgh
    c
            do 100 j=1,5
              ib = next
              do 90 i=ib,ie
                ch  = buff(i)
                last = i
                if( i.eq.jlgh .or. ch.eq.':' )then
                  if( i.eq.jlgh )then
                    done = .true.
                  endif
                  if( ch.eq.':' )then
                    last = i-1
                  endif
                  goto 91
                endif
      90    continue
              goto 98
    c
      91    ipoint = 0
              ik    = 0
              do 92 i=next,last
                ik = ik+1
                ch = buff(i)
                if( ch.eq.'.' )then
                  ipoint = ipoint+1
                endif
                abuf(ik) = buff(i)
      92    continue
              abuf(ik+1) = '$'
    c
              ll = ik
              if( ipoint.eq.0 )then
                call gvali4 (abuf,ll,i4,icond)
                r8 = dble(float( i4 ))
              else
              endif
    c
              k    = k+1
              x(k) = r8
    c
      98    if( done )then
                goto 101
              endif
    c
              next = last
      99    next = next+1
              if( buff(next).eq.':' )then
                goto 99
              endif
      100  continue
    c
    c      load dd,dm,ds
    c
      101  if( k.ge.1 )then
              dd = x(1)
            endif
    c
            if( k.ge.2 )then
              dm = x(2)
            endif
    c
            if( k.ge.3 )then
              ds = x(3)
            endif
          endif
    c
          if( dd.gt.ddmax  .or.
        1    dm.ge.60.0d0 .or.
        1    ds.ge.60.0d0 )then
            ierror = 1
            dd = 0.0d0
            dm = 0.0d0
            ds = 0.0d0
          endif
    c
          if( icond.ne.0 )then
            ierror = 1
          endif
    c
          return
          end
          subroutine elipss (elips)
          implicit double precision(a-h,o-z)
          character*1  answer
          character*30 elips
          common/elipsoid/a,f
          write(*,*) '  Other Ellipsoids.'
          write(*,*) '  -----------------'
          write(*,*) '  '
          write(*,*) '  A) Airy 1858'
          write(*,*) '  B) Airy Modified'
          write(*,*) '  C) Australian National'
          write(*,*) '  D) Bessel 1841'
          write(*,*) '  E) Clarke 1880'
          write(*,*) '  F) Everest 1830'
          write(*,*) '  G) Everest Modified'
          write(*,*) '  H) Fisher 1960'
          write(*,*) '  I) Fisher 1968'
          write(*,*) '  J) Hough 1956'
          write(*,*) '  K) International (Hayford)'
          write(*,*) '  L) Krassovsky 1938'
          write(*,*) '  M) NWL-9D (WGS 66)'
          write(*,*) '  N) South American 1969'
          write(*,*) '  O) Soviet Geod. System 1985'
          write(*,*) '  P) WGS 72'
          write(*,*) '  Q-Z) User defined.'
          write(*,*) '  '
          read(*,10) answer
      10 format(a1)
    c
          if(answer.eq.'A'.or.answer.eq.'a') then
            a=6377563.396d0
            f=1.d0/299.3249646d0
            elips='Airy 1858'
          elseif(answer.eq.'B'.or.answer.eq.'b') then
            a=6377340.189d0
            elips='Airy Modified'
          elseif(answer.eq.'C'.or.answer.eq.'c') then
            a=6378160.d0
            f=1.d0/298.25d0
            elips='Australian National'
          elseif(answer.eq.'D'.or.answer.eq.'d') then
            a=6377397.155d0
            f=1.d0/299.1528128d0
            elips='Bessel 1841'
          elseif(answer.eq.'E'.or.answer.eq.'e') then
            a=6378249.145d0
            f=1.d0/293.465d0
            elips='Clarke 1880'
          elseif(answer.eq.'F'.or.answer.eq.'f') then
            a=6377276.345d0
            f=1.d0/300.8017d0
            elips='Everest 1830'
          elseif(answer.eq.'G'.or.answer.eq.'g') then
            a=6377304.063d0
            f=1.d0/300.8017d0
            elips='Everest Modified'
          elseif(answer.eq.'H'.or.answer.eq.'h') then
            a=6378166.d0
            f=1.d0/298.3d0
            elips='Fisher 1960'
          elseif(answer.eq.'I'.or.answer.eq.'i') then
            a=6378150.d0
            f=1.d0/298.3d0
            elips='Fisher 1968'
          elseif(answer.eq.'J'.or.answer.eq.'j') then
            a=6378270.d0
            f=1.d0/297.d0
            elips='Hough 1956'
          elseif(answer.eq.'K'.or.answer.eq.'k') then
            a=6378388.d0
            f=1.d0/297.d0
            elips='International (Hayford)'
          elseif(answer.eq.'L'.or.answer.eq.'l') then
            a=6378245.d0
            f=1.d0/298.3d0
            elips='Krassovsky 1938'
          elseif(answer.eq.'M'.or.answer.eq.'m') then
            a=6378145.d0
            f=1.d0/298.25d0
            elips='NWL-9D  (WGS 66)'
          elseif(answer.eq.'N'.or.answer.eq.'n') then
            a=6378160.d0
            f=1.d0/298.25d0
            elips='South American 1969'
          elseif(answer.eq.'O'.or.answer.eq.'o') then
            a=6378136.d0
            f=1.d0/298.257d0
            elips='Soviet Geod. System 1985'
          elseif(answer.eq.'P'.or.answer.eq.'p') then
            a=6378135.d0
            f=1.d0/298.26d0
            elips='WGS 72'
          else
            elips = 'User defined.'
    c
            write(*,*) '  Enter Equatorial axis,  a : '
            read(*,*) a
            a  = dabs(a)
    c
            write(*,*) '  Enter either Polar axis, b or '
            write(*,*) '  Reciprocal flattening,  1/f : '
            read(*,*) ss
            ss = dabs(ss)
    c
            f = 0.0d0
            if( 200.0d0.le.ss .and. ss.le.310.0d0 )then
              f = 1.d0/ss
            elseif( 6000000.0d0.lt.ss .and. ss.lt.a )then
              f = (a-ss)/a
            else
              elips = 'Error: default GRS80 used.'
              a    = 6378137.0d0
              f    = 1.0d0/298.25722210088d0
            endif
          endif
    c
          return
          end
          subroutine fixdms (ideg, min, sec, tol )
    c
    c
    c    test for seconds near 60.0-tol
    c
          if( sec.ge.( 60.0d0-tol ) )then
            sec  = 0.0d0
            min  = min+1
          endif
    c
    c    test for minutes near 60
    c
          if( min.ge.60 )then
            min  = 0
            ideg = ideg+1
          endif
    c
    c    test for degrees near 360
    c
          if( ideg.ge.360 )then
            ideg = 0
          endif
    c
          return
          end
          subroutine hem_ns ( lat_sn, hem )
          character*6  hem
    c
          if( lat_sn.eq.1 ) then
            hem = 'North '
          else
            hem = 'South '
          endif
    c
          return
          end
          subroutine hem_ew ( lon_sn, hem )
          character*6  hem
    c
          if( lon_sn.eq.1 ) then
            hem = 'East  '
          else
            hem = 'West  '
          endif
    c
          return
          end
          subroutine getrad(d,m,sec,isign,val)
    *** comvert deg, min, sec to radians
          implicit double precision(a-h,j-z)
          common/const/pi,rad
          val=(d+m/60.d0+sec/3600.d0)/rad
          val=dble(isign)*val
          return
          end
    CB::GPNARC
    C
          SUBROUTINE GPNARC (AMAX,FLAT,ESQ,PI,P1,P2,ARC)
    C
    C********1*********2*********3*********4*********5*********6*********7*
    C
    C NAME:        GPNARC
    C VERSION:    200005.26
    C WRITTEN BY:  ROBERT (Sid) SAFFORD
    C PURPOSE:    SUBROUTINE TO COMPUTE THE LENGTH OF A MERIDIONAL ARC
    C              BETWEEN TWO LATITUDES
    C
    C INPUT PARAMETERS:
    C -----------------
    C AMAX        SEMI-MAJOR AXIS OF REFERENCE ELLIPSOID
    C FLAT        FLATTENING (0.0033528 ... )
    C ESQ          ECCENTRICITY SQUARED FOR REFERENCE ELLIPSOID
    C PI          3.14159...
    C P1          LAT STATION 1
    C P2          LAT STATION 2
    C
    C OUTPUT PARAMETERS:
    C ------------------
    C ARC          GEODETIC DISTANCE
    C
    C LOCAL VARIABLES AND CONSTANTS:
    C ------------------------------
    C GLOBAL VARIABLES AND CONSTANTS:
    C -------------------------------
    C
    C    MODULE CALLED BY:    GENERAL
    C
    C    THIS MODULE CALLS:
    C      LLIBFORE/ OPEN,  CLOSE,  READ,  WRITE,  INQUIRE
    C                DABS,  DBLE,  FLOAT,  IABS,  CHAR,  ICHAR
    C
    C    INCLUDE FILES USED:
    C    COMMON BLOCKS USED:
    C
    C    REFERENCES: Microsoft FORTRAN 4.10 Optimizing Compiler, 1988
    C                MS-DOS Operating System
    C    COMMENTS:
    C::MODIFICATION HISTORY
    C::197507.05, RWS, VER 00 TENCOL RELEASED FOR FIELD USE
    C::198311.20, RWS, VER 01 MTEN  RELEASED TO FIELD
    C::198411.26, RWS, VER 07 MTEN2  RELEASED TO FIELD
    C::1985xx.xx, RWS, CODE  CREATED
    C::198506.10, RWS, WRK    ENHANCEMENTS RELEASED TO FIELD
    C::198509.01, RWS, VER 11 MTEN3  RELEASED TO FIELD
    C::198512.18, RWS, CODE  MODIFIED FOR MTEN3
    C::198708.10, RWS, CODE  MODIFIED TO USE NEW MTEN4 GPN RECORD FORMAT
    C::199112.31, RWS, VER 20 MTEN4 RELEASED TO FIELD
    C::200001.13, RWS, VER 21 MTEN4 RELEASED TO FIELD
    C::200005.26, RWS, CODE  RESTRUCTURED & DOCUMENTATION ADDED
    C::200012.31, RWS, VER 23 MTEN5 RELEASED
    CE::GPNARC
    C    M T E N  (VERSION 3)
    C    M T E N  (VERSION 5.23)
    C
          IMPLICIT REAL*8 (A-H,O-Z)
    C
          LOGICAL  FLAG
    C
          DATA TT/5.0D-15/
    C
    C    CHECK FOR A 90 DEGREE LOOKUP
    C
          FLAG = .FALSE.
    C
          S1 = DABS(P1)
          S2 = DABS(P2)
    C
          IF( (PI/2.0D0-TT).LT.S2 .AND. S2.LT.(PI/2.0D0+TT) )THEN
            FLAG = .TRUE.
          ENDIF
    C
          IF( S1.GT.TT )THEN
            FLAG = .FALSE.
          ENDIF
    C
          DA = (P2-P1)
          S1 = 0.0D0
          S2 = 0.0D0
    C
    C    COMPUTE THE LENGTH OF A MERIDIONAL ARC BETWEEN TWO LATITUDES
    C
          E2 = ESQ
          E4 = E2*E2
          E6 = E4*E2
          E8 = E6*E2
          EX = E8*E2
    C
          T1 = E2*(003.0D0/4.0D0)
          T2 = E4*(015.0D0/64.0D0)
          T3 = E6*(035.0D0/512.0D0)
          T4 = E8*(315.0D0/16384.0D0)
          T5 = EX*(693.0D0/131072.0D0)
    C
          A  = 1.0D0+T1+3.0D0*T2+10.0D0*T3+35.0D0*T4+126.0D0*T5
    C
          IF( FLAG )THEN
            GOTO 1
          ENDIF
    C
          B  = T1+4.0D0*T2+15.0D0*T3+56.0D0*T4+210.0D0*T5
          C  = T2+06.0D0*T3+28.0D0*T4+120.0D0*T5
          D  = T3+08.0D0*T4+045.0D0*T5
          E  = T4+010.0D0*T5
          F  = T5
    C
          DB = DSIN(P2*2.0D0)-DSIN(P1*2.0D0)
          DC = DSIN(P2*4.0D0)-DSIN(P1*4.0D0)
          DD = DSIN(P2*6.0D0)-DSIN(P1*6.0D0)
          DE = DSIN(P2*8.0D0)-DSIN(P1*8.0D0)
          DF = DSIN(P2*10.0D0)-DSIN(P1*10.0D0)
    C
    C    COMPUTE THE S2 PART OF THE SERIES EXPANSION
    C
          S2 = -DB*B/2.0D0+DC*C/4.0D0-DD*D/6.0D0+DE*E/8.0D0-DF*F/10.0D0
    C
    C    COMPUTE THE S1 PART OF THE SERIES EXPANSION
    C
        1 S1 = DA*A
    C
    C    COMPUTE THE ARC LENGTH
    C
          ARC = AMAX*(1.0D0-ESQ)*(S1+S2)
    C
          RETURN
          END
    cb::gpnhri
    c
          subroutine gpnhri (a,f,esq,pi,p1,e1,p2,e2,az1,az2,s)
    c
    c
    c name:        gpnhri
    c version:    200208.09
    c written by:  robert (sid) safford
    c purpose:    subroutine to compute helmert rainsford inverse problem
    c
    c    solution of the geodetic inverse problem after t. vincenty
    c    modified rainsford's method with helmert's elliptical terms
    c    effective in any azimuth and at any distance short of antipocal
    c    from/to stations must not be the geographic pole.
    c    parameter a is the semi-major axis of the reference ellipsoid
    c    finv=1/f is the inverse flattening of the reference ellipsoid
    c    latitudes and longitudes in radians positive north and west
    c    forward and back azimuths returned in radians clockwise from south
    c    geodesic distance s returned in units of semi-major axis a
    c    programmed for ibm 360-195  09/23/75
    c
    c    note - note - note -
    c    1. do not use for meridional arcs and be careful on the equator.
    c    2. azimuths are from north(+) clockwise and
    c    3. longitudes are positive east(+)
    c
    c input parameters:
    c -----------------
    c a            semi-major axis of reference ellipsoid      meters
    c f            flattening (0.0033528...)
    c pi          3.14159...
    c p1          lat station 1                              radians
    c e1          lon station 1                              radians
    c p2          lat station 2                              radians
    c e2          lon station 2                              radians
    c
    c az1          azi at sta 1 -> sta 2                      radians
    c az2          azi at sta 2 -> sta 1                      radians
    c s            geodetic dist between sta(s) 1 & 2          meters
    c
    c aa              constant from subroutine gpnloa
    c alimit          equatorial arc distance along the equator  (radians)
    c arc              meridional arc distance latitude p1 to p2 (in meters)
    c az1              azimuth forward                          (in radians)
    c az2              azimuth back                            (in radians)
    c bb              constant from subroutine gpnloa
    c equ              equatorial distance                      (in meters)
    c s                ellipsoid distance                        (in meters)
    c sms              equatorial - geodesic distance (S - s) "Sms"
    c tol0            tolerance for checking computation value
    c tol1            tolerance for checking a real zero value
    c tol2            tolerance for close to zero value
    c twopi            two times constant pi
    c
    c
    c    module called by:    general
    c
    c    this module calls:  gpnarc, gpnloa
    c      llibfore/ dsin,  dcos,  dsqrt,  dabs,  datan2, write
    c
    c
    c    references: microsoft fortran 4.10 optimizing compiler, 1988
    c                ms-dos operating system
    c    comments:
    c::197507.05, rws, ver 00 tencol released for field use
    c::198311.20, rws, ver 01 mten  released to field
    c::198411.26, rws, ver 07 mten2  released to field
    c::198506.10, rws, wrk    enhancements released to field
    c::198507.22, rws, code  modified for mten3
    c::198509.01, rws, ver 11 mten3  released to field
    c::198708.10, rws, code  modified to use new mten4 gpn record format
    c::199112.31, rws, ver 20 mten4 released to field
    c::200001.13, rws, ver 21 mten4 released to field
    c::200005.26, rws, code  restructured & documentation added
    c::200012.31, rws, ver 23 mten5 released
    c::200104.09, rws, code  added to calblin program
    c::200208.09, rws, code  added subroutines gpnarc & gpnloa
    ce::gpnhri
    c    m t e n  (version 3)
    c              (version 4.22)
    c              (version 5.23)
    c
          implicit real*8 (a-h,o-z)
    c
          data tol0 /5.0d-15/
          data tol1 /5.0d-14/
          data tol2 /7.0d-03/
    c
          twopi = 2.0d0*pi
    c
    c    test the longitude difference with tol1
    c    tol1 is approximately 0.000000001 arc seconds
    c
          ss = e2-e1
          if( dabs(ss).lt.tol1 )then
            e2 = e2+tol1
            write(*,*) ' longitudal difference is near zero '
    c
            r2 = p2
            r1 = p1
            call gpnarc ( a, f, esq, pi, r1, r2, arc )
            s  = dabs( arc )
    c
            if( p2.gt.p1 )then
              az1 = 0.0d0
              az2 = pi
            else
              az1 = pi
              az2 = 0.0d0
            endif
            return
          endif
    c
    c    test for longitude over 180 degrees
    c
          dlon = e2-e1
    c
          if( dlon.ge.0.0d0 )then
            if( pi.le.dlon .and. dlon.lt.twopi )then
              dlon = dlon-twopi
            endif
          else
            ss = dabs(dlon)
            if( pi.le.ss .and. ss.lt.twopi )then
              dlon = dlon+twopi
            endif
          endif
    c
          ss = dabs( dlon )
          if( ss.gt.pi )then
    c::    write(*,*) '  '
    c::    write(*,*) ' Longitude difference over 180 degrees  '
    c::    write(*,*) ' Turn it around '
            ss = twopi-ss
          endif
    c
    c    compute the limit in longitude (alimit), it is equal
    c    to twice the distance from the equator to the pole,
    c    as measured along the equator (east/ewst)
    c
          alimit = pi*(1.0d0-f)
    c
    c    test for anti-nodal difference
    c
          if( ss.ge.alimit )then
            r1 = dabs(p1)
            r2 = dabs(p2)
    c
    c      latitudes r1 & r2 are not near the equator
    c
            if( r1.gt.tol2 .and. r2.gt.tol2 )then
              goto 60
            endif
    c
    c      longitude difference is greater than lift-off point
    c      now check to see if  "both"  r1 & r2 are on equator
    c
            if( r1.lt.tol1 .and. r2.gt.tol2 )then
              goto 60
            endif
            if( r2.lt.tol1 .and. r1.gt.tol2 )then
              goto 60
            endif
    c
    c      check for either r1 or r2 just off the equator but < tol2
    c
            if( r1.gt.tol1. or. r2.gt.tol1 )then
              az1 = 0.0d0
              az2 = 0.0d0
              s  = 0.0d0
              return
            endif
    c
    c      compute the azimuth to anti-nodal point
    c
    c::    write(*,*) '  '
    c::    write(*,*) ' Longitude difference beyond lift-off point '
    c::    write(*,*) '  '
    c
            call gpnloa (a,f,esq,pi,dlon,az1,az2,aa,bb,sms)
    c
    c      compute the equatorial distance & geodetic
    c
            equ = a*dabs(dlon)
            s  = equ-sms
            return
          endif
    c
      60 continue
    c
          f0  = (1.0d0-f)
          b    = a*f0
          epsq = esq/(1.0d0-esq)
          f2  = f*f
          f3  = f*f2
          f4  = f*f3
    c
    c    the longitude difference
    c
          dlon  = e2-e1
          ab    = dlon
          kount = 0
    c
    c    the reduced latitudes
    c
          u1    = f0*dsin(p1)/dcos(p1)
          u2    = f0*dsin(p2)/dcos(p2)
    c
          u1    = datan(u1)
          u2    = datan(u2)
    c
          su1  = dsin(u1)
          cu1  = dcos(u1)
    c
          su2  = dsin(u2)
          cu2  = dcos(u2)
    c
    c    counter for the iteration operation
    c
        1 kount = kount+1
    c
          clon  = dcos(ab)
          slon  = dsin(ab)
    c
          csig  = su1*su2+cu1*cu2*clon
          ssig  = dsqrt((slon*cu2)**2+(su2*cu1-su1*cu2*clon)**2)
    c
          sig  = datan2(ssig,csig)
          sinalf=cu1*cu2*slon/ssig
    c
          w  = (1.0d0-sinalf*sinalf)
          t4  = w*w
          t6  = w*t4
    c
    c    the coefficients of type a
    c
          ao  = f-f2*(1.0d0+f+f2)*w/4.0d0+3.0d0*f3*(1.0d0+
        1        9.0d0*f/4.0d0)*t4/16.0d0-25.0d0*f4*t6/128.0d0
          a2  = f2*(1.0d0+f+f2)*w/4.0d0-f3*(1.0d0+9.0d0*f/4.0d0)*t4/4.0d0+
        1        75.0d0*f4*t6/256.0d0
          a4  = f3*(1.0d0+9.0d0*f/4.0d0)*t4/32.0d0-15.0d0*f4*t6/256.0d0
          a6  = 5.0d0*f4*t6/768.0d0
    c
    c    the multiple angle functions
    c
          qo  = 0.0d0
          if( w.gt.tol0 )then
            qo = -2.0d0*su1*su2/w
          endif
    c
          q2  = csig+qo
          q4  = 2.0d0*q2*q2-1.0d0
          q6  = q2*(4.0d0*q2*q2-3.0d0)
          r2  = 2.0d0*ssig*csig
          r3  = ssig*(3.0d0-4.0d0*ssig*ssig)
    c
    c
          s  = sinalf*(ao*sig+a2*ssig*q2+a4*r2*q4+a6*r3*q6)
          xz  = dlon+s
    c
          xy  = dabs(xz-ab)
          ab  = dlon+s
    c
          if( xy.lt.0.5d-13 )then
            goto 4
          endif
    c
          if( kount.le.7 )then
            goto 1
          endif
    c
    c    the coefficients of type b
    c
        4 z  = epsq*w
    c
          bo  = 1.0d0+z*(1.0d0/4.0d0+z*(-3.0d0/64.0d0+z*(5.0d0/256.0d0-
        1        z*175.0d0/16384.0d0)))
          b2  = z*(-1.0d0/4.0d0+z*(1.0d0/16.0d0+z*(-15.0d0/512.0d0+
        1        z*35.0d0/2048.0d0)))
          b4  = z*z*(-1.0d0/128.0d0+z*(3.0d0/512.0d0-z*35.0d0/8192.0d0))
          b6  = z*z*z*(-1.0d0/1536.0d0+z*5.0d0/6144.0d0)
    c
    c    the distance in meters
    c
          s  = b*(bo*sig+b2*ssig*q2+b4*r2*q4+b6*r3*q6)
    c
    c    first compute the az1 & az2 for along the equator
    c
          if( dlon.gt.pi )then
            dlon = (dlon-2.0d0*pi)
          endif
    c
          if( dabs(dlon).gt.pi )then
            dlon = (dlon+2.0d0*pi)
          endif
    c
          az1 = pi/2.0d0
          if( dlon.lt.0.0d0 )then
            az1 = 3.0d0*az1
          endif
    c
          az2 = az1+pi
          if( az2.gt.2.0d0*pi )then
            az2 = az2-2.0d0*pi
          endif
    c
    c    now compute the az1 & az2 for latitudes not on the equator
    c
          if( .not.(dabs(su1).lt.tol0 .and. dabs(su2).lt.tol0) )then
            tana1 =  slon*cu2/(su2*cu1-clon*su1*cu2)
            tana2 =  slon*cu1/(su1*cu2-clon*su2*cu1)
            sina1 =  sinalf/cu1
            sina2 = -sinalf/cu2
    c
    c      azimuths from north,longitudes positive east
    c
            az1  = datan2(sina1,sina1/tana1)
            az2  = pi-datan2(sina2,sina2/tana2)
          endif
    c
          if( az1.lt.0.0d0 )then
            az1 = az1+2.0d0*pi
          endif
    c
          if( az2.lt.0.0d0 )then
            az2 = az2+2.0d0*pi
          endif
    c
          return
          end
    CB::GPNLOA
    C
          SUBROUTINE GPNLOA (AMAX,FLAT,ESQ,PI,DL,AZ1,AZ2,AO,BO,SMS)
    C
    C
    C NAME:        GPNLOA
    C PURPOSE:    SUBROUTINE TO COMPUTE THE LIFF-OFF-AZIMUTH CONSTANTS
    C
    C INPUT PARAMETERS:
    C -----------------
    C PI          3.14159...
    C DL          LON DIFFERENCE
    C AZ1          AZI AT STA 1 -> STA 2
    C
    C AZ2          AZ2 AT STA 2 -> STA 1
    C AO          CONST
    C BO          CONST
    C SMS          DISTANCE ... EQUATORIAL - GEODESIC  (S - s)  "SMS"
    C
    C
    C
    C      LLIBFORE/ DSIN,  DCOS,  DABS,  DASIN
    C
    C
    C    COMMENTS:
    CE::GPNLOA
    C              (VERSION 4.22)
    C              (VERSION 5.23)
    C
    C
          DATA TT/5.0D-13/
    C
          DLON = DABS(DL)
          CONS = (PI-DLON)/(PI*FLAT)
          F    = FLAT
    C
    C    COMPUTE AN APPROXIMATE AZ
    C
          AZ  = DASIN(CONS)
    C
          T1  =    1.0D0
          T2  =  (-1.0D0/4.0D0)*F*(1.0D0+F+F*F)
          T4  =    3.0D0/16.0D0*F*F*(1.0D0+(9.0D0/4.0D0)*F)
          T6  = (-25.0D0/128.0D0)*F*F*F
    C
          ITER = 0
        1 ITER = ITER+1
          S    = DCOS(AZ)
          C2  = S*S
    C
    C    COMPUTE NEW AO
    C
          AO  = T1 + T2*C2 + T4*C2*C2 + T6*C2*C2*C2
          CS  = CONS/AO
          S    = DASIN(CS)
          IF( DABS(S-AZ).LT.TT )THEN
            GOTO 2
          ENDIF
    C
          AZ  = S
          IF( ITER.LE.6 )THEN
            GOTO 1
          ENDIF
    C
        2 AZ1  = S
          IF( DL.LT.0.0D0 )THEN
            AZ1 = 2.0D0*PI-AZ1
          ENDIF
    C
          AZ2  = 2.0D0*PI-AZ1
    C
    C    EQUATORIAL - GEODESIC  (S - s)  "SMS"
    C
          ESQP = ESQ/(1.0D0-ESQ)
          S    = DCOS(AZ1)
    C
          U2  = ESQP*S*S
          U4  = U2*U2
          U6  = U4*U2
          U8  = U6*U2
    C
          T1  =    1.0D0
          T2  =    (1.0D0/4.0D0)*U2
          T4  =  (-3.0D0/64.0D0)*U4
          T6  =    (5.0D0/256.0D0)*U6
          T8  = (-175.0D0/16384.0D0)*U8
    C
          BO  = T1 + T2 + T4 + T6 + T8
          S    = DSIN(AZ1)
          SMS  = AMAX*PI*(1.0D0 - FLAT*DABS(S)*AO - BO*(1.0D0-FLAT))
    C
          RETURN
          END
          subroutine gvali4 (buff,ll,vali4,icond)
    c
          logical      plus,sign,done,error
          character*1  buff(*)
          character*1  ch
    c
    c    integer*2    i
    c    integer*2    l1
    c
          integer*4    ich,icond
          integer*4    ll
          integer*4    vali4
    c
          l1    = ll
          vali4 = 0
          icond = 0
          plus  = .true.
          sign  = .false.
          done  = .false.
          error = .false.
    c
          i = 0
      10 i = i+1
          if( i.gt.l1 .or. done )then
            go to 1000
          else
            ch  = buff(i)
            ich = ichar( buff(i) )
          endif
    c
          if(    ch.eq.'+' )then
    c
    c      enter on plus sign
    c
            if( sign )then
              goto 150
            else
              sign = .true.
              goto 10
            endif
          elseif( ch.eq.'-' )then
    c
    c      enter on minus sign
    c
            if( sign )then
              goto 150
            else
              sign = .true.
              plus = .false.
              goto 10
            endif
          elseif( ch.ge.'0' .and. ch.le.'9' )then
            goto 100
          elseif( ch.eq.' ' )then
    c
    c      enter on space -- ignore leading spaces
    c
            if( .not.sign )then
              goto 10
            else
              buff(i) = '0'
              ich = 48
              goto 100
            endif
          elseif( ch.eq.':' )then
    c
    c      enter on colon -- ignore
    c
            if( .not.sign )then
              goto 10
            else
              goto 1000
            endif
          elseif( ch.eq.'$' )then
    c
    c      enter on dollar "$"
    c
            done = .true.
            goto 10
          else
    c
    c      something wrong
    c
            goto 150
          endif
    c
    c    enter on numeric
    c
      100 vali4 = 10*vali4+(ich-48)
          sign  = .true.
          goto 10
    c
    c    treat illegal character
    c
      150 buff(i) = '0'
          vali4 = 0
          icond = 1
    c
    1000 if( .not.plus )then
            vali4 = -vali4
          endif
    c
          return
          end
          subroutine gvalr8 (buff,ll,valr8,icond)
    c
          logical      plus,sign,dpoint,done
    c
          character*1  buff(*)
          character*1  ch
    c
    c    integer*2    i, ip
    c    integer*2    l1
    c    integer*2    nn, num, n48
    c
          integer*4    ich,icond
          integer*4    ll
    c
          real*8      ten
          real*8      valr8
          real*8      zero
    c
          data zero,ten/0.0d0,10.0d0/
    c
          n48    =  48
          l1      =  ll
          icond  =  0
          valr8  =  zero
          plus    = .true.
          sign    = .false.
          dpoint  = .false.
          done    = .false.
    c
    c    start loop thru buffer
    c
          i = 0
      10 i = i+1
            go to 1000
          else
            ch  = buff(i)
            nn  = ichar( ch )
            ich = nn
          endif
    c
          if(    ch.eq.'+' )then
    c
    c
            if( sign )then
              goto 150
            else
              sign = .true.
              goto 10
            endif
    c
    c
            if( sign )then
              goto 150
            else
              sign = .true.
              plus = .false.
              goto 10
            endif
          elseif( ch.eq.'.' )then
    c
    c      enter on decimal point
    c
            ip    = 0
            sign  = .true.
            dpoint = .true.
            goto 10
            goto 100
    c
    c      enter on space
    c
            if( .not.sign )then
              goto 10
            else
              buff(i) = '0'
              ich = 48
              goto 100
            endif
          elseif( ch.eq.':' .or. ch.eq.'$' )then
    c
    c      enter on colon or "$" sign
    c
            done = .true.
            goto 10
          else
    c
    c      something wrong
    c
            goto 150
          endif
    c
    c    enter on numeric
    c
      100 sign = .true.
          if( dpoint )then
            ip = ip+1
          endif
    c
          num  = ich
          valr8 = ten*valr8+dble(float( num-n48 ))
          goto 10
    c
    c
      150 buff(i) = '0'
          valr8  =  0.0d0
          icond  =  1
    c
    1000 if( dpoint )then
            valr8 =  valr8/(ten**ip)
          endif
    c
          if( .not.plus )then
            valr8 = -valr8
          endif
    c
          return
          end
          subroutine todmsp(val,id,im,s,isign)
    *** convert position radians to deg,min,sec
    *** range is [-pi to +pi]
          common/const/pi,rad
        1 if(val.gt.pi) then
            val=val-pi-pi
            go to 1
          endif
        2 if(val.lt.-pi) then
            val=val+pi+pi
            go to 2
          endif
          if(val.lt.0.d0) then
            isign=-1
          else
            isign=+1
          endif
          s=dabs(val*rad)
          id=idint(s)
          s=(s-id)*60.d0
          im=idint(s)
          s=(s-im)*60.d0
    *** account for rounding error
          is=idnint(s*1.d5)
          if(is.ge.6000000) then
            s=0.d0
            im=im+1
          endif
          if(im.ge.60) then
            im=0
            id=id+1
          endif
          return
          end
          subroutine trim (buff,lgh,hem)
    c
          character*1 ch,hem
          character*1 buff(*)
          integer*4  lgh
    c
          ibeg = 1
          do 10 i=1,50
            if( buff(i).ne.' ' )then
              goto 11
            endif
            ibeg = ibeg+1
      10 continue
      11 continue
          if( ibeg.ge.50 )then
            ibeg = 1
            buff(ibeg) = '0'
          endif
    c
          iend = 50
          do 20 i=1,50
            j = 51-i
            if( buff(j).eq.' ' )then
              iend = iend-1
            else
              goto 21
            endif
      20 continue
      21 continue
    c
          ch = buff(ibeg)
          if( hem.eq.'N' )then
            if( ch.eq.'N' .or. ch.eq.'n' .or. ch.eq.'+' )then
              hem = 'N'
              ibeg = ibeg+1
            endif
            if( ch.eq.'S' .or. ch.eq.'s' .or. ch.eq.'-' )then
              hem = 'S'
              ibeg = ibeg+1
            endif
    c
    c      check for wrong hemisphere entry
    c
            if( ch.eq.'E' .or. ch.eq.'e' )then
              hem = '*'
              ibeg = ibeg+1
            endif
            if( ch.eq.'W' .or. ch.eq.'w' )then
              hem = '*'
              ibeg = ibeg+1
            endif
          elseif( hem.eq.'W' )then
            if( ch.eq.'E' .or. ch.eq.'e' .or. ch.eq.'+' )then
              hem = 'E'
              ibeg = ibeg+1
            endif
            if( ch.eq.'W' .or. ch.eq.'w' .or. ch.eq.'-' )then
              hem = 'W'
              ibeg = ibeg+1
            endif
    c
    c
            if( ch.eq.'N' .or. ch.eq.'n' )then
              hem = '*'
              ibeg = ibeg+1
            endif
            if( ch.eq.'S' .or. ch.eq.'s' )then
              hem = '*'
              ibeg = ibeg+1
            endif
            if( .not.('0'.le.ch .and. ch.le.'9') )then
              hem = '*'
              ibeg = ibeg+1
            endif
          else
    c        do nothing
          endif
    c
    c
          do 30 i=ibeg,iend
            ch = buff(i)
    c
            if(    ch.eq.':' .or. ch.eq.'.' )then
              goto 30
            elseif( ch.eq.' ' .or. ch.eq.',' )then
              buff(i) = ':'
            elseif( '0'.le.ch .and. ch.le.'9' )then
              goto 30
            else
              buff(i) = ':'
            endif
    c
      30 continue
    c
    c    left justify buff() array to its first character position
    c    also check for a ":" char in the starting position,
    c    if found!!  skip it
    c
          j  = 0
          ib = ibeg
          ie = iend
    c
          do 40 i=ib,ie
            if( i.eq.ibeg .and. buff(i).eq.':' )then
    c
    c        move the 1st position pointer to the next char &
    c        do not put ":" char in buff(j) array where j=1
    c
              ibeg = ibeg+1
              goto 40
            endif
            j = j+1
            buff(j) = buff(i)
      40 continue
    c
    c
          lgh = iend-ibeg+1
          j  = lgh+1
          buff(j) = '$'
    c
    c    clean-up the rest of the buff() array
    c
          do 50 i=j+1,50
            buff(i) = ' '
      50 continue
    c
    c    save a maximum of 20 characters
    c
          if( lgh.gt.20 )then
            lgh = 20
            j  = lgh+1
            buff(j) = '$'
          endif
    c
          return
          end
    Lex K-G likes this.
  3. Lex K-G
    Lex K-G Форумчанин
    Прошу прощения, трудно писать на мобиле- живет своей жизнью, вопросительный знак отвергает))) Редактировать ошибки - проще застрелиться
    Это оффтоп.
    --- Сообщения объединены, Oct 8, 2013, Оригинальное время сообщения: Oct 8, 2013 ---
    я у ТС просил фортран))))
  4. Дядя Вова
    Ага, ты ещё ассемблер у него попроси.
  5. Lex K-G
    Lex K-G Форумчанин
    Да ладно вам, может он под мобилу че интересное пишет.
  6. Lex K-G, на Java под мобилу, да :-) А на фортране только считать же, а не программы писать.
  7. Lex K-G
    Lex K-G Форумчанин
    А что конкретно, если не секрет
  8. Дядя Вова
    В далёком 84-м. мною со товарищем, была написана программа вычисления эфемерид звёзд на момент наблюдения, а вы говорите только считать...
    А кумпутеры какие были! ЕС1065, СМ-3...
    Эх были времена....::drink1.gif::
    Иоан4 and 39dotyt like this.
  9. Lex K-G
    Lex K-G Форумчанин
    Spoiler
    А сколько на ём накоплено фунций для инженерных и научных рассчетов;) Да, еще и BERNEESE написан на Фортране.
    39dotyt likes this.
  10. stout
    Intel так не считает: Using Intel® Visual Fortran to Create and Build Windows*-Based Applications
    Хотя вы правы, писать GUI на фортране — это ещё то извращение.
    Spoiler
    Хочу уточнить, программа вычисления эфемерид или приведения на видимое место? Или и то и другое?
    Где-то чуть раньше принесли мне магнитную ленту с каталогом SAO (Smithsonian Astrophysical Observatory), о структуре которого ничего не было известно. На ЕС-ке лента читалась поблочно, но понять что к чему месяца два не мог. Пока не сообразил, что записана она была на машине, где в одном байте было шесть бит.
    Когда в ЦГЧ поставили ЕС-1060, а затем расширили объём оперативной памяти до одного мегабайта, все не верили такому счастью, каждый в карточках JCL заказывал этот вожделенный мегабайт!
    Некоторым через полгода работы машины мегабайта стало мало. Таких программистов начальник отделения майор Жидков в приказном порядке переводил на ЕС-1036, где было 256 Кб. И ставил задачу — через три месяца комплекс должен работать на ЕС-1036.
    И вот, самое удивительное, не было никого, кто бы не справился с поставленной задачей!::biggrin24.gif::
    Ну, для нормальной работы ещё Пёрл вроде бы был нужен. Для полного счастья не хватает 856000 рублей - цена коммерческой версии.
    Радует, что увеличилось количество поддерживаемых трансляторов.
    Кстати, GAMIT тоже почти весь на фортране.
    Lex K-G and 39dotyt like this.
  11. Дядя Вова
    Насколько я помню и то и другое. Хотя могу ошибаться - времени то прошло...
    39dotyt likes this.
  12. Lex K-G
    Lex K-G Форумчанин
    Spoiler
    А можно ли где-то нарыть исходники оных? Пытался искать - не получилось...
    39dotyt likes this.
  13. Дядя Вова, не забывайте о таких вещах как сложность и скорость разработки) Быстро написать надёжную распределённую производительную расширяемую систему на фортране обломишься ведь. А вот JavaScript + node.js (внезапно), например, пожалуйста :-)
    Lex K-G, таки почему вы спрашиваете? :-) Мобильный клиент для водителя к системе диспетчеризации транспортных средств.
    --- Сообщения объединены, Oct 9, 2013, Оригинальное время сообщения: Oct 9, 2013 ---
    Мы конечно думали на Erlang всё писать :-)
  14. Lex K-G
    Lex K-G Форумчанин
    Spoiler
    Для расширения кругозорности и вкурседельности в целях профилактики старомаразмости головных мозгов.)))
    stout and 39dotyt like this.
